Hot Door CADtools 10.3.3 (x64) for Adobe Illustrator | 102.3 MB
Sail through any design project with CADtools 10 for Adobe Illustrator. Draw in any scale, edit and dimension vector artwork with a mouse-click, and numerically control objects or points. All 87 tools and 12 panels are elegant, easy, and powerful to make every journey smooth and successful.
CADtools 10 glides with simplicity, offering hundreds of new scalable symbols, built-in help, and a friendly dashboard for controlling all CAD features. Conquer the seas with sinuous waves, precise grids, and repeated objects along paths - all within the world's leading drawing application.
- Instantly reference help with in-app, context-sensitive user guide and 1-minute video tutorials
- View cursor tips that prompt how to use tools
- Access hundreds of editable symbols for architecture, people, and landscape that automatically scale to the target layer
- Organize CADtools tools and panels in one location with CADdashboard
- Easily access tool settings with improvements in the CADcontrol bar
- Add scale markers to maps and other designs with the Scale Line tool
- Repeat objects with precision with Repeat and Repeat Along Path tools
- Create precision signage using the Scaled Type tool
- Click-drag grids in a snap
- Click-drag waves or create them numerically
- Transform objects independently on their own axes in CADtracker
- Add company logos to CADtools title blocks
- Select new units for extremely small and large scales
- Draw Illustrator art in any scale - document or layer-based
- Use the simple scale calculator for extra help
- View scaled CADrulers and CADgrids
- Create and adjust walls and insert doors/windows
- Project art to axonometric/isometric planes for 3D effect
- Create cubes and cylinders with axonometric/isometric tools
- Draw grids and waves with numeric control
- Create instant titles and tables with easy numeric input
- Access hundreds of symbols of architecture, people, and landscaping
- Click-drag dimensions with custom style or text
- Dimension every possible object, path, or points in space
- Create live dimensions that follow and respond to artwork changes
- Measure area, perimeter and length of one or more paths
- Create custom labels with text, numbers, alphabet or object geometry
- Numerically move and transform objects on group or independent axes with CADtracker
- Project or dimension flat art in axonometric view
- Create fillets, chamfers, and profiles on object corners
- Click to trim and extend paths to create precise intersections
- Slice paths into equal parts with the path divider tool
- Create offsets for vector paths, including numeric control
- Repeat objects in grid or along path with numeric precision
- Resize art in scale with proportion and scaled type tools
- Learn features fast with the context-sensitive, in-app user guide and 1-minute video tutorials
- Auto-dimension objects in the CADshortcuts panel
- Save or load CADtools settings as shareable Preset files
- Work fast with keyboard input while dragging dimensions, labels, doors/windows, polygons, rounded rectangles, grids, and waves to edit shapes on-the-fly
Adobe Illustrator CC 2017.
nitroflareKod:https://uploadgig.com/file/download/88aaB16bf48d3F70/4p3dMi0p_CADtools.10.3.3.rar
rapidgatorKod:http://nitroflare.com/view/B2F96BAD4E2366F/4p3dMi0p_CADtools.10.3.3.rar
turbobitKod:https://rapidgator.net/file/a48d0569e73a746a2911f88589d39675/4p3dMi0p_CADtools.10.3.3.rar.html
Kod:http://turbobit.net/fyndcicon947/4p3dMi0p_CADtools.10.3.3.rar.html
