Product Name:Fuel monitoring gauge, TL800 to monitor the fuel level change of various fuel tanks
Traclogis Co.,Ltd is well-known as a professional fuel monitoring gauge, tl800 to monitor the fuel level change of various fuel tanks suppliers among those professional fuel monitoring gauge, tl800 to monitor the fuel level change of various fuel tanks manufacturers in China. We have a productive and efficient factory and our fuel monitoring gauge, tl800 to monitor the fuel level change of various fuel tanks is sold at a cheap price. Please feel free to contact us.Product DetailBasic InfoModel NO.:TL800Type:Fuel Level SensorContact:ContactOutput Signal Typeigital and AnalogFeature:CuttableMaterial:MetalIP Rating:IP67Certification:CECustomized:CustomizedSi gnal Output:0-5V , ,RS232 ,RS485,4-20mAPackage:Neutral Carton PackageSpecification:10-200CMOrigin:ChinaHS Code:90269000Product Description?TL800 capacitive fuel level sensor cuttable sensor·Product feature of lpg level transmitterWith capacitance as the sensing element, FLS sensor series continuously detects theFuel level with resolution less than 1mm.Sensor length can be trimmed to fit tanks ofVarying heights.It serves as an excellent solution for GPS fuel tracking applicationsWith its high resolution.With a?wide range of power input ,and easily adjustable lengthThe FLS is easy to setup and works for a?wide range of application .·Technical?parameter of lpg level transmitterStandard?Length?55CM,75CM,100CM,150CMMi n&Max?Length10-3000mmFree?Cutting?Back?upSignal?Output?Analog?0-5v?,4-20mADigital?RS232/485ResolutionFS?0.1%?(0.1mm)MaterialAluminium?Allo ySignal?Refresh?5S/timeWorking?Temperature?-40°C?~?+85°C??/-40F?~?+185F?Power4V~70VMax?Electricity?Current<15m AProtection?RankIP65Not?applicable?in?conducting?m edium?.Calibration?of?the lpg level transmitterCalibration of the fuel sensor is calibration the full level and empty level .The fundamental principle is to record a full value and empty value in the fuel sensor when tank is full and empty ;The purpose is to define the position level of the fuel when it is full and empty in the tank.The electrical signal changes as the fuel level changes ,calculating the height of the fuel level .?Note:When the fuel sensor is shortened ,it needs to be calibrated .Calibration to empty level and full level is related to the medium and the liquid level ,instead of volume of the tank ;this operationcan be operated in room (make a container ,simulate a full fuel tank by filling the container full ).First ,calibrate full level ,then the empty level ,or else the sensor could not enter the setting mode .???Calibration?of?full?level?Fill the tank to desired full level ,put the sensor into the tank ,wait for about 30 seconds until the aluminum tube of sensor was filled with fuel,then press and hold on the "F"button on the calibrator for 5 seconds till the green LED light slowly flickers .This indicates that calibration for full level is in progress .Release the "F"button at this moment .The green LED light will turn off in about 10 seconds ,indicating that the calibration of the full level is comlete .??Calibration?of?empty?level?Remove the sensor from the container /tank .After liquid fully drains from the sensor ,press and hold on the "E"button for about 5 seconds until the green LED light starts to flicker fast .This indicates that calibration for empty level is in progress .Release the "E"button at this moment .The gree LED light will turn off ater about 10 seconds ,indicating that calibration of the empty level is complete . The?Traclogis?capacitive fuel level sensor TL800?can work any GPS tracking devices around the world.???? Main?Products:?Driver?Fatigue?Monitor?? Ultrasonic fuel level sensor?
Price:10.00
Traclogis Co.,ltd
Address:GuangdongGuangdongDongguanLiaobu7/F block ,80 Bldg Huanan Industrial Park Liaobu Town Dongguan
Descption:Established in 2009, Traclogis is dedicated to provide Fuel control system and Fuel consumption monitoring solution and GPS-GSM/GPRS vehicle monitoring and fleet management sensors that has a transformative effect on the way business optimize their fleet and mobile assets.?
With the development of modernization in industry and agriculture, and the wide use of industry monitoring and automatic management, the wireless control system is expanding rapidly, especially in irrigation works and electronic power, fuel consumption, with the strong demands from the market, Traclogis started the remote fuel monitoring solution study in 2009, based on the experience of fleet management solutions, we have released the complete solution of remote fuel monitoring solution successfully, which has helped our customers saving a lot of cost on the management of fleet and industrial equipment operation.
Registered Capital:100
EmployeeNum:100
Traclogis Co.,ltd
Contact:AllenLi
Telphone:86-86-1234569-0
Fax:86-86-1234569-0
Email:traclogisallen@aliyun.com
