Product Name:Professional Metal Parts Sandblasting Machine Small With Dust Collector
Professional metal parts Sandblasting ?Machine Small With Dust CollectorSandblasting Machine Small With Dust ?Collector Dry sand blast cabinet with dust collect ,separator ,blast gun with nozzle ,glovesdry sand blast cabinet ?are suitable for surface treatment of all products of metal, plastic and glass etc .removing oxide skin. residues burrs and scratches can be used for decoration light .matte and strengthen management , There are cyclone separation system and dust removal system , separator will separate the abrasive from bust .and dust removal system can deal with and collect the ? ?emit useless dust .and can vibrating clean up dust automatically .dust remove effect of good .reduce the cost of abrasive and improve efficiency .and there is no environmental pollution .ModeOutside size (L*W*H mm)CABIN size(L*W*H mm)HX-90601050*950*1580900*600*580HX-90801250*950*1580900*800*580HX-10101420*1050*19001000*1000*800HX-12121620*1250*20001200*1200*800Power supply:220V(380V). 50HZLighting:flood light incandescent lamp 220V, 13WSeparator motor:220V, 50HZ, 0.75KWCompressed air supplyry and clean compressed air with ? ?pressureat 2.8-7bar(kg/cm2) and flow of ? ?0.5-1.1m3/min1m3/min 7.5KW 10HP (1 gun )Dust removal:Bag-type dust collector, powder clearance ? ?by compressed air vibrationAbrasiveWhite Aluminum Oxide.Brown Aluminum ? ?Oxide.Glass Beads;(150-320mesh)
Price:10.00
Huzhou Shuanglin Hengxing Polishing Equipment Factory
Address:ZHEJIANGZHEJIANGHUZHOUSHUANGLINJISHUIGANG ROAD (WEST), SHUANGLIN TOWN, HUZHOU CITY, ZHEJIANG PROVINCE, CHINA
Descption:HUZHOU SHUANGLIN HENGXING POLISHING EQUIPMENT FACTORY established in 1980s is one of the well-know manufacture of surface finishing industry in China.
HENGXING dedicates to providing high quality products and advanced technology on surface polishing for customers and manufactures from all type of industries.
HENGXING will persistently provide reliable quality products and high quality service
to customers through R&D development and professional management in future.
Registered Capital:500
EmployeeNum:80
Contact:ZHANG JUN
Telphone:86-572-3972679-0
Fax:86-572-3972388-0
Email:13567229585@139.com
