Product Name:Energy Saving PO-CO-01-01470B Hydraulic Suction Oil Filter For SANY Excavator Parts
Suction Oil Filter characteristics
1.Good filtration performance, even surface filtration performance of 2-200um filtration particle size
2. Good corrosion resistance, heat resistance, pressure resistance and wear resistance;
3. Uniform and precise filtering accuracy of stainless steel filter pores;
4. The stainless steel filter element has a large flow per unit area;
5. The stainless steel filter element is suitable for low temperature and high-temperature environment;
Filter element structural strength:
1) Axial rigidity: When the filter element is subjected to the axial load standard of industrial process documents, it should not cause deformation and damage.
(2) Flattening rigidity: When the filter element withstands the ultimate pressure drop of the industrial process file standard, it should not deform and damage.
(3) Pressure drop flow characteristic: The pressure drop flow characteristic curve of the standard filter element should be used in the industrial process file.
(4) Flow fatigue characteristics: Under standard flow and pressure drop conditions. The number of flow fatigue cycles of disposable filter elements is not less than 10,000 times, and the number of flow fatigue cycles of reusable filter elements is not less than 20,000 times.
Price:11.00
Hangzhou Dingteng Industrial Co.,Ltd
Address:zhejiangzhejianghangzhoujiangganThe 12 Floor No.2Building Xifuhui Business Center.Hongpu Road Jianggan District, Hangzhou,Zhejiang province
Descption:Hangzhou Dingteng Industrial Co., Ltd, the professional excavator parts supplier in China for more than 10 years.
We provide all parts for SANY excavator, so its convenient for you if you want to buy kinds of parts together. And also please do not worry about the price and quality! We totally have advantage in price and quality compared with foreign trade company.
Our excavators and parts are exported to South Africa Ghana Banglade South America the United States Germany Brazil United Kingdom Russia Japan Australia South Korea India France and so on.
We supply all kinds of SANY excavator parts:
Such as pump walking motor rotary motor assembly and parts boom and arm cylinders seal repair kits all kinds of filter bucket bucket tooth and all undercarriage parts and so on.
That is to say, whatever which model of SANY excavator parts you need, we totally could help you.
Our business principle is:
"quality and service first, continuous improvement and innovation to meet the customers requirement" and "zero defect, zero complaints" as the quality objective.
Registered Capital:100
EmployeeNum:100
Contact:Marc Ma
Telphone:86-000-0000000-0
Fax:86-000-0000000-0
Email:chinesesupplier@aliyun.com
