Product Name:100Kg Food Heat Conductive Oil Drum Freeze Dryer
Specifications
Model
KFD-10
Freeze-drying Shelf Area (m2)
10
Shelf Temp. (℃)
-35℃~+100℃
Shelf Temp. Uniformity
±1 ℃
Cold Trap Temp.
≤ -45℃
Dewatering (Kg)
220
Ultimate Vacuum (Pa)
<10
Cooling Water Flow Volume (T/H)(≤25℃)
8
Defrosting Method
Water Flood
Total Power (KW)
40
Shelf Qty (PCS)
11+1
Shelf Size (LxW,mm)
2200*600
Shelf Space (mm)
70
Installation Weight(kg)
4000
Features
PLC control system
Water cooling system
Mirror polished stainless steel chamber with round corners and strengthening ribs
Bearing positive and negative pressure from 0.15MPa to 0.5PA
Mirror-polished stainless steel cold trap with water vapor channel to ensure small molecule moving resistance and high water-capturing efficiency
World-class compressor, safe and stable
Vacuum system with automatic tracking welding
Side leakage of vacuum is tested with helium mass spectrometer to ensure high vacuum
LCD display for working status, system running history and record, alarm and alarm history, parameter setting, saving and recall
Self diagnostic system
Application
Vacuum Freeze Dryer is an advanced Hi-Tech dehydration technology, It makes hydrous materials frozen in the low temperature status, then under the vacuum condition, it adopts thermal radiation method for heating, to sublimate ice to gas directly. After the moisture comes out, it uses ice-condenser (cold trap) and vacuum device to dehydrate the water content. It is a combined application technology based on multidisciplinary development, including refrigeration, heating, vacuum, biological, electrical and etc. Vacuum freeze drying technology has widely application, such as for chemical products, biologics, health product, herbs, agricultural products ( meat, poulty, egg, sea food, vegetables and fruits and etc.)
How Healthy Is Freeze-Dried Fruit?
Freeze-dried fruit is similar to dried fruit, because it has been dehydrated, but it has a crunchy texture. The nutrients that freeze-dried fruit contains offer several health benefits, making it a good addition to a well-balanced diet.
√ Low In Calories
√ High in Fiber
√ 100% Antioxidants Preserved
√ Natural Sweetness, No Added Sugar,
√ Nutrients As Fresh Fruit
If the 100kg food heat conductive oil drum freeze dryer caters to your requirement, welcome to buy the precise equipment made in China from our factory. We are one of the professional manufacturers and suppliers in China who can offer you unmatched services and prices. And the customized service is also available. Don't hesitate any more.
Price:11.00
Hangzhou KASSEL Machinery co., ltd
Address:zhejiangzhejianghangzhouyuhangNO.3, WANHE RD, GAOQIAO IND. ZONE, CANGQIAN TOWN, YUHANG HANGZHOU, CHINA
Descption:Kassel Machinery (Hangzhou) Co., Ltd. has been founded in China to introduce Kassel Group advanced technology and management concepts. At the same time, the company set up offices in Ningbo, Shanghai and Suzhou for your convenience.
Under the technical support from KASSEL, Kassel cares not only product quality, but also pays more attention to developing new quality products including the following characteristics: high efficiency, energy saving and environmental protection. The major products are Oil-operated temperature control system, Water-operated temperature control system, and industrial chillers.
Kassel team of engineering, sales and service professionals are dedicated to supplying the high quality and safe products in the industry.
Kassel - a value driven manufacturer that delivers practical engineering solutions with superior customer focus and support. Designed to Perform, Built to Last.
Registered Capital:1000000
EmployeeNum:40
Contact:adolph
Telphone:86-571-88617051-0
Fax:86-571-88617051-0
Email:kasseltemperaturecontrol@aliyun.com
